? cold weather
Old Dec 2, 2002 | 07:09 PM
harescrambler's Avatar
Default ? cold weather
will cold weather affect my top speed notice a 4mph differance in top speed now that it's 20degrees colder
Old Dec 2, 2002 | 07:13 PM
StevieD's Avatar
maybe...
your in dunmore huh? cool. im like a half hour from there.
Old Dec 2, 2002 | 07:22 PM
RedHondaRancherES2x4's Avatar
I have noticed mine backfires alot in cold weather.
Old Dec 2, 2002 | 07:29 PM
Mike Chero's Avatar
The reason it is running slower is because it is running leaner because of the cold weather. When the weather gets cold, the air molecules move together. This makes the engine run leaner. Rejet to a 1 size richer main jet and probably a 1 size richer pilot jet and the problem will go away.
Old Dec 2, 2002 | 08:24 PM
Snowride's Avatar
I know my Xplorers would go like a bat out of heel when the temps got to about 30 below but that is flirting with meltdown. I normally rejet about 10 bigger for the cold weather (stock 310 use 320 for colder temps) If you are running a four stroke you will be fine. Try adding some gas line anti freeze. See the other topic, cold weather.
Old Dec 2, 2002 | 11:32 PM
mojave300ex's Avatar
It will run lean because theirs like no humidity in the air when it's cold (below 32*), humidity thickens air.
Old Dec 2, 2002 | 11:41 PM
Snowride's Avatar
mojave300ex
Cold has nothing to do with humidity. It can be -40 and 90% humidity. Take a look at the temps and humidity here right now.My Temps
Old Dec 2, 2002 | 11:57 PM
FOX250's Avatar
my 4-wheeler goes much faster in the cold
~jenny
Old Dec 4, 2002 | 06:35 PM
it's a 500 scr its 4 mph slower the plug is light tan with the chop test the air box is modded with six uni vents i'll try plugging the six holes giving me a more gas less air resulting in richer mixture should increase my top speed back to original speed that is if it's lean what? about clutch weights lighter or heavier for cold weather
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
