Float bowl drain plug leaking
Old Dec 13, 2002 | 06:36 PM
Brugie's Avatar
Default Float bowl screw leak
After doing some jet work on my '02 400 EX, fuel leaks from the float bowl drain plug. I have tightened it as tight as I can get it without possibly stripping the threads. Any suggestions.......
Thanks!
Old Dec 13, 2002 | 06:50 PM
RacinJason's Avatar
It doesn't sound good...try replacing the gasket on the float bowl and using a tiny amount of silicon on the screws....they shouldn't be so tight you can't get them back off
BRAAAAP
Old Dec 13, 2002 | 07:01 PM
Brugie's Avatar
It's not the screws that hold the float bowl on the carb. It is the large drain plug/access hole for the main jet that is on the bottom of the float bowl. Should I use a sealant of some sort?
Old Dec 13, 2002 | 10:16 PM
moto93's Avatar
Default Float bowl drain plug leaking
Maybe the o-ring fell off when you had it apart? Just a thought.
skinnyr6
Aug 25, 2023 02:18 AM
slowgsxr97
Mar 18, 2022 03:40 AM
SDR-II
Sep 29, 2015 01:06 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
