Does your 650 engine fan run alot?
Old Dec 15, 2002 | 09:02 PM
Andy~G's Avatar
Default Does your 650 engine fan run alot?
Mine does. Even slow ridding in cool weather {50 degrees} will cause the fan to run almost all the time.
Is this normal?
My radiator is perfectly clean and is full of water.
Does anyone know what temp thermostat the 650 has? Is there a cooler one available?
Andy G
Old Dec 15, 2002 | 10:22 PM
Ross650's Avatar
Howdy,
My fan used to run a lot. I use the additives from High-Lifter. One goes in the radiator coolant and the other goes in the oil. These have cut my fan running about in half. I have used them for over a year and have not had any problems. Have a goodun!!
Old Dec 15, 2002 | 10:32 PM
AJ650's Avatar
Your fan should run more often at low speed than at moderate speeds as there is less air flow through the radiator itself. As long as the fan doesn't run consantly, you should be ok.
Old Dec 16, 2002 | 07:27 AM
nyroc's Avatar
Also, make sure there is absolutely no mud in it.
Muffler wrap on the head pipe near the radiator cools things off quite a bit I hear. Some people have cut holes in the plastic guards oun the outlet side of the rad (up high) in an effort to improve air flow at low speeds. They claim it helped.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
ronnierhino06
Nov 9, 2015 12:56 PM
GNorm
Aug 1, 2015 11:06 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
