Grips
Old Apr 6, 2000 | 04:57 PM
bad2bone's Avatar
Does anyone know where I can get padded hand grips for my wife's Sportsman? I have found heated, but not padded.
Thanks!
Old Apr 6, 2000 | 06:11 PM
Rammer's Avatar
I put Oury (sp?) grips on the wife's Xplorer. They are alot softer than the stock ones. Bought them at the dealer. I have a neat trick to change them if you would like to know.
Old Apr 8, 2000 | 07:31 AM
bad2bone's Avatar
Where did you find them? And yes, I'd like to hear the trick to installation.........
Thanks!
Old Apr 8, 2000 | 10:47 AM
Rammer's Avatar
I bought them at the dealer for around 10 bucks I think. To remove them, punch a hole in the end of each one. Using compressed air, put the air gun into on side, and your finger in the other. When you hit the trigger,the grips will expand and slide right off. Only use as much pressure as needed. To install, start one grip on and punch a hole it the end. Put hand over the other side and gun into the new grip. You will need very little pressure, as the new grips are alot softer. Do the same for the other one. Always hold onto both when you have air applied, it's amazing how far a grip can launch off the bars.
black_thunder
Sep 7, 2015 01:24 AM
erntee61
Aug 9, 2015 02:54 PM
Stirling
Aug 9, 2015 01:49 PM
Scottma518
Jul 10, 2015 12:42 AM
ScoobyDFW
Feb 3, 2000 11:58 PM
