split case?
Old Dec 22, 2002 | 11:16 AM
Hurycne's Avatar
Default split case?
Who has split the cases on the DS to get the crank out? Anything special to watch for?
Old Dec 22, 2002 | 12:10 PM
Majorecho's Avatar
Default split case?
It's a pretty straight forward procedure, you'll need the magnito puller
and the clutch basket holder to be able to remove and properly retorque all bolts. Also the middle plastic gear behind the clutch between the upper and lower oil pumps has to be removed to split the case. I could not find any instruction for this step in the shop manual and stumped me a few minutes. Also lay the motor on it's right(magnito side) as you are separating the two halves, this will keep the gears in places and keep the job more simple.
The following link gives some good ideas and pictures on tearing the rotax 650 downtear down
if you have any questions, just ask.
Old Dec 22, 2002 | 05:30 PM
Hurycne's Avatar
Default split case?
Will do. What about the flywheel puller? Do I need that?
Old Dec 22, 2002 | 06:35 PM
Majorecho's Avatar
Default split case?
magnito/flywheel puller are one and the same. Check with you BMW dealer on the puller it's supposed to be cheaper than the Bomb dealers.
Old Dec 22, 2002 | 06:50 PM
Hurycne's Avatar
Default split case?
I think the puller will be my hold up
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
WilliamBos
Sep 22, 2015 04:07 PM
1ArmBandit
Sep 8, 2015 08:59 PM
