ds 650 steel rims
Old Dec 28, 2002 | 09:34 PM
bellracing's Avatar
Default ds 650 steel rims
Has anyone seen or know where to get steel rims for the ds ? I've tried douglass and itp with no luck . Thanks , Bellracing
Old Dec 28, 2002 | 10:32 PM
SANDMAN430's Avatar
have you tried rocky mountain? 1-800-336-5437
Old Dec 29, 2002 | 12:29 AM
BlackHawk's Avatar
Does the DS have the same bolt pattern as the Bombardier utility quads? If it does, I'm sure you'll have lots of options for the utility market.
Old Dec 29, 2002 | 01:35 AM
brad650's Avatar
why do you want to buy steel rims?? get some alum ones
Old Dec 29, 2002 | 08:26 PM
lilnotts's Avatar
steel rims are cheaper n stronger
Old Dec 30, 2002 | 11:24 PM
Bellracing2's Avatar
Thanks Lil, some one is on the same page as me. Thats exactly what i'm talking about. I found that the 400 ex is only 1 mm off on the front pattern but the rear will have to be redrilled to the ds pattern.
Old Dec 30, 2002 | 11:29 PM
SANDMAN430's Avatar
i thought the ds is 143 front and back.
Old Dec 30, 2002 | 11:32 PM
1WickedDS's Avatar
Although the Honda pattern is only 1MM off on the bolt pattern, the hub center is smaller on the Honda, so they will not fit without modifying the wheels or the hub. Once you get them over the studs, they will be about 1/2" to 3/4" away from seating on the hub.
Old Dec 30, 2002 | 11:37 PM
northjeepster's Avatar
I'll take those carbon fiber ones!!!!
Old Dec 30, 2002 | 11:39 PM
lilnotts's Avatar
i looked too but i couldn't find any, i ended up buyin itp aluminum rims
