Fuses or Fuseable links ?
[img]i/expressions/face-icon-small-confused.gif[/img]Can't seem to find any fuses or fuseable links on my 02 500ho,and there is no info in the owners manual on this subject.Can any one help me out with this?I don't have any problems with the electrical system I just want to learn a bit about it.
I dont think there is any fuses or fusable links on atv's. Everything is hard wired. You can only get so much voltage from the stator and voltage spikes are very rare. Not like a vehical. Cars can run 12 to14.7 volts but can have spikes and if the voltage regulator goes bad, posative and ground wires touch, or some freak thing, fuses can protect the electrical system. ATV's dont have much more than 12 volts running through them.
Hondas use fuses, located in a box behind the battery. Polaris uses circuit breakers which reset when the short is removed; excess load is removed; or when unit cools down. An example would be a loaded winch motor causing the breaker to overheat, will take a while for it to reset.
