homemade lift kit - prairie 650
Old Jan 7, 2003 | 01:05 AM
Nemmeh's Avatar
Default homemade lift kit - prairie 650
Anyone done this themselves?
I was thinking about doing it, but I really don't know what is involved in the process. I'm sure I could get a machine shop to make some brackets for me. Anyone got any pictures of theirs or give any tips on doing this yourself.
Just wondering before I spend money on it.
Old Jan 7, 2003 | 01:55 AM
TrailHog's Avatar
I've got something to add, I'm going to try to make the stock springs on the front adjustable by using a short piece of threaded conduit pipe with the locking conduit nuts, it should work. I can pick up on the front end 3'' it seems like before the tires come off the ground.
Old Jan 7, 2003 | 09:45 PM
mastrblastr's Avatar
Nemmeh, I made a 1 1/4 inch lift for mine but I have access to a machine shop. I made spacers that screw right onto the top of the front struts to lift the front end. On the rear end, I removed the rear shock, cut the bottom end off the shock and made a new one approximately 1 inch longer to give it the 1 1/4 lift to match the front. Welded it back together and reinstalled the shock.
I looked at the Perfex lift and it is a POS. Wouldn't waste my money.
Trailhog, I machined a donut shaped piece about 1/2 inch thick that I installed on the front struts between the spring and the shock. Gave the front end quite a bit more preload to keep it from bottoming out. Seems to work pretty good.
Old Jan 7, 2003 | 10:03 PM
NovaKaw650's Avatar
Don't push the shock to the top of it's travel with your new adjusters. For the suspension to work properly you need 1/3 of the susp. travel at the top and 2/3 at the bottom. This allows the suspension to droop when the tires come to holes in the trails. If there is no "droop", the tires can't follow the contours of the trailbed. Hard on the machine and the driver.
Old Jan 8, 2003 | 12:48 AM
TrailHog's Avatar
Novakaw650 I was thinking the same thing, but it's got to much sag. Remember when the single shock bikes came out? That was the main difference in the ride, like you said, because the suspension works both ways, not just up, like the old dual shock dirt bikes I had. The rear shock needs adjusting, but I won't do it until I can do the front too because of increasing the sag that much more on the front.
mastrblastr I'm going to try the same thing except make them adjustable. There may be no need to make them adjustable.
Old Jan 8, 2003 | 07:31 AM
mojavekid13's Avatar
Mastrblastr I cant beleave u welded a pice on the bottom! Man i woudl have been affrid of it BLOWING up
Old Jan 8, 2003 | 09:13 PM
Mojavekid, it's the top that has all the pressure in it. The bottom end of the shock is safe to work on. I wrapped it with a fire retardant blanket before I welded on it to make sure I didn't get any spatter on the rod. It was the cheapest rear lift kit out there!!!
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
QuadRiders
Oct 22, 2015 04:13 PM
PrairieDog126
Sep 12, 2015 05:23 PM
Cantbuytime
Aug 16, 2015 09:13 PM
