how well does the stage two hot cam work in the woods?
Old Jan 10, 2003 | 03:25 AM
derbyking's Avatar
Default how well does the stage two hot cam work in the woods?
anybody running this cam ride in the tight stuff?
Old Jan 10, 2003 | 09:51 AM
Ernie660R's Avatar
I would not think you should have any problems just as long you have the rpm's up in the 1400 to 1500 range.
Old Jan 10, 2003 | 01:09 PM
14mins's Avatar
Derbyking- You will like that cam with your motor. To me it makes a better riding quad. Easier to get around. Not always standing straight up.
Old Jan 10, 2003 | 01:39 PM
PatsRaptor's Avatar
14mins what do you mean by that??( not always standing straight up) compared to the stage 1 with all the mid range????stage 1 more torque stage 2 all around smoother power to the top???
Old Jan 10, 2003 | 05:42 PM
2strokeDiehard's Avatar
As long as you add some compression to make up for the loss of low end it works fine. I like it better then the smaller cams in the woods !!
Old Jan 10, 2003 | 06:25 PM
PatsRaptor's Avatar
I'm going with a 12.1 piston but can't decide which cam to get. Everybody that has the stage 1 loves it. I want really strong mid range
Old Jan 10, 2003 | 06:39 PM
14mins's Avatar
Patsraptor- I think the stage 2 is over hyped (race cam) It is more biased toward the top-end. Example- If the stock cam peaks at 6500 rpm, the stage 1 is around 7000 and the stage 2 is 7500. I do not have the exact numbers in front of me. Ernie has a 11-1 and a stage 2 cam. I think he is real happy. If i put a stage 1 back in mine it will pop a whellie everytime i give it a little gas. I can put-put around or haul a## on mine. It is very rideable.
Old Jan 10, 2003 | 07:06 PM
PatsRaptor's Avatar
Thanks 14mins that is the BEST answer I have heard about the difference between the 2 cams..
People talk that you can get deals on the Hotcams???? Can you get me a price on a stage 1
delaos1@msn.com
THANKS AGAIN
Pat
Old Jan 10, 2003 | 11:25 PM
derbyking's Avatar
14mins,have you had to machine the center intake guide?i read on hotcams website that the clearance would have to be ck,d.
Old Jan 10, 2003 | 11:32 PM
Ernie660R's Avatar
Derbyking, I run a stage two Hot Cam and have not any clearance problems with the center valve or guide, or for that fact any of the valves. I also shaved .015 of the head and do not have any problems. The stage two cam has good torque but really good mid and top end. 14mins sold me everything at good prices, nobody could match it.
