Grease zerk on stock bearing carrier?
i don't believe it would work, since the way the chain tensioner is built i don't think its possible,someone just came out with a new carrier with built in zerk fitting, i thinks its $250 and comes with bearings, it is found here,and no you don't need it, but it sure would lengthen the life of the bearings and save you money
This is why I asked the question!
http://home.swbell.net/tharthun/home...ingcarrier.htm
You might want to check those axle bearings once in awhile!
well i think my bearings might be starting to go again [img]i/expressions/face-icon-small-sad.gif[/img], so i might look into which would be cheaper in the long run, does anyone know the number of the tapered bearings in the stock ds?
Here you go:
DS-650 axle bearing/seal replacement parts.
Bomb
Qty. Part # Description Price/each
(2) 293350025-BNRNG-cone 25.99
(2) 293250115-oil seals- 9.19
(1) 705500191-wear sleeve- 14.79
(1) 293300059-O-ring .79
(1) 705500108-retainer ring 1.39
(1) 293300060 O-ring .79
(1) 705500065-retainer ring 1.79
BTW, I will be ordering the rad billet tapered bearing carrier for mine.
Bomb
