carb adjustment
Old Jan 11, 2003 | 12:39 AM
ironhead's Avatar
Default carb adjustment
Has anyone adjusted their idle mixture screws on a 03 650? Where are they at on the carbs and what is the best way to get to them? And how many turns out should they be? Also what is a good price for a kawasaki service manual?
Old Jan 11, 2003 | 12:43 AM
bodyman's Avatar
Adjusting the idle screws helps with intake backfire and helps it start a little eaiser. They are located on the right side, one on each carb. Just use a small flat screwdriver. 3 turns out usually does the trick.
Old Jan 15, 2003 | 03:39 AM
rammy's Avatar
hey bodyman
is that 3 turns out from the stock position or after you turn them all the way in then turn them 3 turns out?
Old Jan 15, 2003 | 08:10 AM
bodyman's Avatar
Turn them in untill lightly seated, and then 3 turns out.
Old Jan 15, 2003 | 04:03 PM
alltoys's Avatar
Ironhead
Try this for setting your carbs.
Turn in the screw untill the motor runs rough take note at position of turns out from bottom eg. 2 1/4 turns. Next turn out the mixture screw untill the motor wants to run fast almost takes off, take note at number of turns out from bottom eg 3 1/2 turns out. Next turn in the screw to half way between the two and you should be okay eg. almost 3 turns or 2 7/8 turns out. Repeat this for both cylinders. From this setting you can vary it by 1/8 of a turn untill you are totally satisfied although I have found it doesn't vary much only say 3/4 of a turn at most either way
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
