red spring insalation
Old Jan 12, 2003 | 04:57 PM
BONEshock's Avatar
Default red spring insalation
is the pully right hand or left hand thred???what is the bolt supposed to be torqed to????thanx
Old Jan 12, 2003 | 07:49 PM
Nightryder888's Avatar
it is normal thread, as for the torqe i dunno
Old Jan 12, 2003 | 11:18 PM
KISSSOFDEATH's Avatar
BONEshock, the threads are left handed. Turn the bolt clockwise for loosening. You also have a direction arrow on the drive pulley cover to remind you. 69ft-lbs of torque is the spec for the bolt.
I used a wooden dowel rod inserted through the outer pulley beside the spring and down into the floorboard to hold the pulley while I tightend the bolt with a torque wrench.
Old Jan 13, 2003 | 01:15 AM
spanker650's Avatar
Can you also loosen the nut using the wooden dowl? I don't have an impact wrench and I've been trying to get it off and I'm up to 100 ft. lbs. and it's not budging. Is there a chance of damaging something? Didn't have this much of a problem when I put in the black spring. Thanks for the info Kiss of Death, Boneshock is my son.
Old Jan 13, 2003 | 02:47 AM
Hi Spanker650. I always used an impact but I guess you could use the wooden dowl for removal too. The proper way to remove and install that bolt is to hold the hold the recoil stater pulley with a hook wrench on the opposite side of the engine. That is more work but would insure you wouldnt damage anything. We have a hook wrench that comes with our P650 in the tool pack but Im not sure if it would fit.
How are you holding the drive pulley now?
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
