Mag 325 brake noise
Old Jan 13, 2003 | 05:33 PM
Sue's Avatar
Sue
Default Mag 325 brake noise
'02 Mag 325 has approx 10 hrs on it and the rear brake makes lot of noise when backing up. The foot brake also bottoms out and doesn't have much brake action. It obviously has air in it and needs bleeding.
Has anybody had same experiences ?
Foot brake appears to be separate system from hand brake because there are 2 bleed screws on caliper.
I am really impressed how well the brakes work using the hand brake.
Old Jan 13, 2003 | 08:14 PM
redrider101's Avatar
my dads 325 mag does the same thing when backing up, i dont know what it is, it is the same year as yours and the dealer has tried to fix it but it still happens?
Old Jan 13, 2003 | 10:22 PM
Firehawk's Avatar
My 325 Magnum does the same thing. After I rode it hard it went away for awhile but came back. I plan on taking a look at it sometime this winter.
Old Jan 14, 2003 | 12:05 AM
PRAIRIETWIN's Avatar
Heavy Duty Semi-metalic Brake Pads. They are noisy!
Ask your dealer about adjustment on rear brake.
Old Jan 20, 2003 | 01:48 PM
Sue's Avatar
Sue
I bleed foot brake system and it did have air in it. Works great now and brakes still make some noise backing up, but not as bad as it did.
Old Jan 21, 2003 | 07:34 AM
elroy2's Avatar
That squeek is, the nature of the beast. I have seen the pads get a little dirt stuck in them and squeek. This will usually go away on its own unless it picks up more dirt. From what you are saying though, I don't believe you'll ever get rid of it. Besides you ought to hear what mine sounds like when I hit the brakes while backing up."SKREECH,GRIND, GROUL" and thats because my brake rotor is mounted to the countershaft. So, their is nothing I can do about it.
mrtidy
Feb 3, 2016 05:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
