SP600 oil filter #?
Old Jan 17, 2003 | 01:37 PM
Arcosanti's Avatar
Default SP600 oil filter #?
I asked a few weeks ago and nobody replied, so I'll ask again. Anyone found a cross reference # for the Polaris oil filter on a 03 SP600? I've checked with a few auto places, and they can't look one up. At about $12 a pop, I don't want to be going back to the dealer for too many more.
I know $12 every few months isn't much, but I change my oil and filter much more frequently than required.
Arcosanti
Old Jan 17, 2003 | 03:17 PM
Expert140's Avatar
I haven't seen an exact replacement for the twin motor oil filter yet. The only real difference between that one and the one the fits on a 500 is that the 600/700 filter has a bypass feature built in. When (or if) the filter becomes plugged it's designed to still flow oil. It just won't be filtering any oil. Which is obviously bad but at least the motor won't burn down right away. Take your Polaris filter to an auto parts store and snoop around, open some filter boxes, you'll probably find something that'll be the same. Also, give it a year...the filter prices will come down as more twins are sold.
Old Jan 17, 2003 | 06:03 PM
Bill35's Avatar
There was a guy on here a while back on here that said he found a match for the 700 at napa auto parts you mite check there...
Old Jan 17, 2003 | 06:28 PM
Rammer's Avatar
I crossed the Polaris 2540006(600-700) filter to the Fram Ph 5343, Wix 51357 and the Napa 1357. I've never haven't tried any, so check these out.
Old Jan 20, 2003 | 10:07 AM
Arcosanti's Avatar
Thanks for the help guys, I'll see what I can find with that Fram and Napa filters.
Arcosanti
Old Mar 28, 2003 | 04:57 PM
Samurai1's Avatar
DID THE CROSS REFERENCE WORK FOR YA AND WHAT BRAND DID YOU GO WITH
Old Mar 29, 2003 | 12:22 PM
MarkV's Avatar
I used the Napa filter on my 700, and it works great. It's less than half the price of the Polaris filter, too!
Old Mar 29, 2003 | 01:18 PM
Surveyor's Avatar
for what it is worth,
the Napa filters are made by wix, and are very good in my opinion, I run a NAPA gold on my v4 yamaha street bike, and am very pleased with it. carquest filters may also be made by wix, as the parts # are the same, or similar. bear in mind that I run synth oil in my quad & street bikes and is in there a little longer than 3 months at a time, or 3K miles, but that is my preference. a friend of mine has a v4 that has 115K on it, and the clutch plates were at the lower end of the specs.. fitment of the filter should be similar to yamaha street bikes, or mazda 1.8L miata, just see if the stock filter has a recess in it where the threads are, or a large nut on the stem that the filter screws to. if this is the case, you need a recessed filter, or it will leak around the sealing area..
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
