Outlaws on Rubicon???
Old Jan 17, 2003 | 10:26 PM
bearstomper's Avatar
Default Outlaws on Rubicon???
I've been thinking about putting 26-10-12, 26-12-12 Outlaws on my 02 Rubicon. Wondering if they will shake my teeth out??? Is the mud performance worth it and can you trail ride between mudholes without to much trouble?
Old Jan 18, 2003 | 01:01 AM
TEXMud's Avatar
I have been running 28 inch outlaws for years now. They are made for 100% mud. With that said, they are not designed for trails.
Old Jan 18, 2003 | 11:52 AM
Harw's Avatar
Take a look at the XL Mud Lite by ITP in 26" they have a deep lug and a center lug so your teeh stay in. they seem to be a good tire for all around. But do not go with the 12" wide on the back use the 10" wide all the way around they will work better.
Old Jan 20, 2003 | 03:51 AM
nick01's Avatar
A good mud tire is definatly worth the money if your going to use it and if you only use a couple of pounds of air in each tire it will ride ok.
Old Jan 23, 2003 | 10:18 PM
Well, bit the bullet and ordered some Green Outlaws (on sale). Should be here tomorrow. I guess I'll see what I think for sure now! Thanks for the info.
GREEN!!! so ugly they have to be cool, but the main thing-Cheap!-comparatively anyway
Old Jan 24, 2003 | 09:05 PM
SWAMPBEAR's Avatar
How did you do with the Outlaws, how did they ride.
Old Jan 25, 2003 | 12:27 AM
GILTYLER's Avatar
My brother in law has them on his 2000 450 es they are rough at slow speed I have ridden it alot.
They will pull any mud you can find and give your rig that built for mud look.
Those green ones are unique.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 25, 2003 | 07:13 PM
They do pretty good, haven't really put them to the test yet. Need to put them in the black hole-without ice! Could barely stay on bike at first (30+ psi), but wanted to make sure the beads were good and set. Just aired them down about 1 hour ago to 9psi and it made a big difference. Still rough at low speed but better. Not so squirrely. They definately grip any thing they touch.
Old Jan 25, 2003 | 08:25 PM
SWAMPBEAR's Avatar
You need to let me put them on the Bear with the locker to put them to the test.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 26, 2003 | 04:47 AM
nick01's Avatar
With 9psi in an any atv tire it would ride kind of bad, if you go over rocks and a lot of bumps that would jar you around I would recommend about 3.5-5psi. Hope this helps
