03' REV LIMITER CDI
Old Jan 19, 2003 | 05:25 AM
DSJOBBER's Avatar
Default 03' REV LIMITER CDI
Rumor mill has it that for '03 the rev limiter on the baja is the same as the standard model. Can anyone confirm this? Also why is Alba revlimiter so much more than Ron Woods model? Alba model says not for use on BAJA model. If there the same now is a new CDI even needed?
Old Jan 19, 2003 | 07:33 AM
bombrider's Avatar
I think its the other way around, the standard ds now has the baja CDI.
the ALBA CDI costs more then the rw\pami cdi's beacouse it has a rev limit, its jast higher, and i think its the cdi as in the bmw f650, weach basecly has the same motor
Old Jan 19, 2003 | 05:29 PM
Hightower's Avatar
All true - standard and baja have same rev limit for '03, but its still too low.
Alba unit has limit, but so does the graydon unit.
Alba just likes to jack the price on stuff they sell - $100 for a rev limit! yikes!
I don't worry about the rev limiter - if I rev it too high its my own fault, not the ignition's.
Old Jan 19, 2003 | 07:30 PM
1prokiwi's Avatar
Hightower , could u modify an existing Graydon )! model CDI to fit the new Baja model ???? is it just a plug connection difference . ?
Old Jan 19, 2003 | 07:33 PM
MadBaja819's Avatar
Yes it is just a simple plug change and your on your way.
Old Jan 19, 2003 | 07:55 PM
1prokiwi's Avatar
Can u buy the new plug seperately or is this something for an electrician to do ??
Old Jan 20, 2003 | 08:53 AM
bombrider's Avatar
You dont need to get a new plug, you jast remove a pin from the existing one and your all set (sorry but i dont know wich one, do a search, there was a post on this a wile back).
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
