I need help
Old Jan 19, 2003 | 01:42 PM
TrueSpeed's Avatar
Default I need help
[img]i/expressions/face-icon-small-confused.gif[/img] My dad just shipped me a 2000 polaris 325 magnum 2x4 from Arizona to Indiana. I can't get it to start up it sounds like its going to crank but never turns over. I have also tried to pull start it. Dad says he had no problems with the ATV when it was at his house. Could the difference in temperature and altitude be effecting the ignition system. My friend told me I may need to adjust the jetting I'm not sure how to do that. I have ordered and owners manual but it takes 2 weeks to get here. Any help would be much appreciated.
Old Jan 19, 2003 | 02:58 PM
wisconsinrider's Avatar
Default I need help
check and see if you have spark first this may sound stupid but is the kill switch turned on
good luck and remember sometimes it's the operator not the machine
Old Jan 19, 2003 | 03:27 PM
matts250's Avatar
Default I need help
what about the fuel switch. i think its under the left front fender. at least it is for my trailblazer.
Old Jan 19, 2003 | 03:32 PM
TrueSpeed's Avatar
Default I need help
Thank you for the help i will go try it now.
Old Jan 19, 2003 | 04:19 PM
TrueSpeed's Avatar
Default I need help
None of this hlped any thing else.
Old Jan 19, 2003 | 04:24 PM
Polaris69's Avatar
Default I need help
this may sound stupid, but is there gas in it? and maybe check the oil?
Old Jan 19, 2003 | 04:56 PM
ftwflh's Avatar
Default I need help
Check the battry voltage.If it has 12v cold it should start but try it with the pull rope so not to run it down.If it was tipped in shipping it might take a shot of starting fluid to help prime it.NOT MUCH JUST A QUICK SHOT..
