mudlites?
Old Jan 20, 2003 | 07:42 PM
Nightryder888's Avatar
Default mudlites?
im thinking about getting a set of these in the future and have a couple of questions. 1) will they fit the stock rims? 2) how much are they w/o rims 3)i want something with a little more bite then the stock tires, but not enough bite to rut up the lawn, will these tires work? thanks in advance for your responses
Old Jan 20, 2003 | 09:58 PM
jjs3788's Avatar
Default mudlites?
1. They will fit stock rims
2. They are in the neighborhood of $60-65 a piece, give or take a few bucks
3. They will tear up the backyard, especially if you corner hard or the ground is wet.
I have the 27's and they are a really nice tire.
Old Jan 20, 2003 | 10:11 PM
Chuckybrown's Avatar
Default mudlites?
As long as you leave it in neutral, your lawn will be fine.... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 21, 2003 | 02:18 AM
Streetrod's Avatar
Default mudlites?
jjs3788, Do the 27" tires make your ATV Tippy?....Next time what size will you buy?
Old Jan 21, 2003 | 06:41 AM
jjs3788's Avatar
Default mudlites?
I noticed in your sig that you have the progressive springs so I think they will be fine for you. The only thing I noticed was that when I went into a corner a little hard it seemed a slight bit tippier. I am attributing this to the fact that I still have the soft front stock suspension. Before when cornering with the Dunlops they would roll under a little and the suspension would dive a little, now that there is a six ply tire on there and it wont roll under, the front of the bike dives a little more. Its not bad, I just had to get used to the way it felt. I am guessing with new springs out front I wouldnt have this anymore.
Old Jan 21, 2003 | 01:47 PM
EasterEgg's Avatar
Default mudlites?
I put 26`s on my P650 stock wheels. The fit was fine and they look great they were $289 to my door.
Old Jan 21, 2003 | 02:49 PM
goggleyed's Avatar
Default mudlites?
I have the 27's & think they are a great tire. Only regret is that I wish I would have gone with the 26's to keep it a little more on the sporty side.
Old Jan 21, 2003 | 04:34 PM
Streetrod's Avatar
Default mudlites?
Are the 26" mudlites taller than stock Dunlops?
Old Jan 21, 2003 | 08:43 PM
Default mudlites?
thanks, how much difference would there be if i stuck with 25" instead of 26" (trying to save all the money i can!) the biggest i will go is 26" will i need stiffer front springs if i go much bigger? and should i stick with the same width as stock? (8-12 front, 10-12 rear)
Old Jan 22, 2003 | 10:33 AM
goggleyed's Avatar
Default mudlites?
The biggest differance between the 25's & 26's is the lug size. I believe the lugs are shorter on the 25's vs the 26's & 27's. The 26's & 27's are only available in one size- 10" up front & 12" for the rear.
jwkawi
Jul 28, 2003 06:11 PM
1fitman
Jun 8, 2003 04:23 PM
yamaguy
Apr 19, 2003 10:32 PM
Mount
Apr 6, 2003 02:24 PM
