Realtors on pred rims??
Old Jan 23, 2003 | 03:05 PM
Scotts88's Avatar
Default Realtors on pred rims??
What size..if any..will fit stock predator rims??
Also where is the best (cheapest) place to get them from?? Thanks!
Old Jan 23, 2003 | 03:24 PM
Scotts88's Avatar
Oh..and which sproket will i need to change to keep the gearing where it is?? Will i need a new chain?
Old Jan 23, 2003 | 03:55 PM
Idontknow's Avatar
get 20" tires and the gearing will stay the same, at least i would think. and i don't know about where to get them, ask someone else that. and you won't need a new chain if you don't change the gearing.
Old Jan 23, 2003 | 06:10 PM
Scotts88's Avatar
See they dont make a 20" realter...im thinking the only one will be the 22*12*10..will this fit on my stock rim?
How bad will the gearing be with it like this???
Old Jan 23, 2003 | 07:10 PM
GE4x4's Avatar
The gearing on the Predator is a little high stock. So if you put 22" tires on, you will be worse. To keep your stock gearing with 22" tires, you will have to go with a 13 tooth front sprocket or a 40 tooth rear. I put a 13 on mine with stock tires , and is where I want it. I would go to a 13 front first. It's easier and cheaper. You can get one from sprocker speacialist for a 02 xr650L of a Honda.
Old Jan 23, 2003 | 07:15 PM
Scotts88's Avatar
well thats a US company..no good for me..i'll have to check around here for one..but with this new sproket..i'll need a new chain right??
Old Jan 23, 2003 | 07:18 PM
GE4x4's Avatar
NO, you will not need a new chain. You will have to tighten it after the install.
Old Jan 23, 2003 | 07:24 PM
Scotts88's Avatar
Sweet..no new chain! Thanks!
Old Jan 23, 2003 | 07:50 PM
Scotts88's Avatar
Ok..i found some 13tooth ones...but it has to be a certain size eh? like all 13tooth sprokets are the same size are they?? I think the one i found was for a honda 250R
Old Jan 23, 2003 | 10:53 PM
Scotts88's Avatar
Ok..did some looking up..alot of people say go with the rear..why..the swap looks pretty much the same..? How much more is the front then the rear? Finding this xr650L 13tooth has been harder then i thought..but i can get a 38 from the dealer..would 38 be enough..or would i have to go with a 40??
And if i put my stock tires back on..will i be geared too low? or just right??
