What is good pipe & air filter for the 03 wolverine?
Old Jan 23, 2003 | 08:00 PM
Wolverine31's Avatar
Default What is good pipe & air filter for the 03 wolverine?
Any reccomendations?
Old Jan 23, 2003 | 11:29 PM
SpDdEmOn's Avatar
I like my White Brothers E-Series and the K&N filter. You can get a More expensive pipe like a Graydon, LRD, or Paul Turner, they are all good pipes too. Supertrapp is a cheaper pipe but is still popular on the Wolveirne.
Old Jan 24, 2003 | 12:21 AM
CTATV's Avatar
I have my Wolverine and I don't have experience with other pipes besides mine but I like my FMF megamax. If you go to albaaction.com you can get the kit for the wolverine that comes with the FMF or the alba pipe ( alba makes a good pipe too), torque stuffer, and K&N filter with precharger, and oh yea jets for the carb. I am happy with mine. Even with the skidplates I added it lifts the front end off the ground on pavement when i hit the gas. definatly didn't do that before. Have only had it in the winter I have yet to hit the dirt trails with it.
Old Jan 24, 2003 | 11:22 AM
Would you guys say you saw a noticeable change in torque? Did you have to rejet? If so is it just the main and the pilot jet change? I'm from NH so Ct is not that far away. Did you Rejet?
Old Jan 24, 2003 | 01:49 PM
SpDdEmOn's Avatar
Oh yeah man you can tell a difference. Its not like piping a raptor but its deffintely there. My pipe is set up so that you can put it on and not rejet when it comes out of the box with 12 discs. You can rejet it then but you dont have to. Ive played around with it and you can rejet it then and make a little more power, but when you run more discs, say 20-24 work good then you have to rejet, its a little louder and runs a bit better. When you rejet it, its just the main jet you replace. Does CT make a pipe than will work on the Wolverine? I imagine that it would be a Warrior slip on but that would bolt right on a Wolveirne.
Old Jan 24, 2003 | 02:00 PM
So you run the white bros E-Series & A torque Stuffer? How Many discs does it come with? Where did you get the jet kit and Pipe? I just want to see some kind os bottom end improvement.
Old Jan 24, 2003 | 03:48 PM
CTATV's Avatar
the kit is from www.albaaction.com
I did rejet and I would definatly sugest doing it. I don't know about carbs but the local mechanic also used to race ducati bikes and do a lot of custom high performance bike/clasic car work. I had them jet it for me. the Megamax has 11 disks in total
Old Jan 24, 2003 | 04:23 PM
CTATV, Did you see a difference in power with the alba kit you got?
Old Jan 24, 2003 | 07:15 PM
And are all wolverine kits the same alba sells, Because mine is a 2003?
Old Jan 24, 2003 | 10:41 PM
Still around Guys? Help[img]i/expressions/face-icon-small-smile.gif[/img]
