Yellow Spring ?????
Old Jan 25, 2003 | 10:12 PM
BCLINEHAND's Avatar
Default Yellow Spring ?????
Ordered the black spring today............ Yippeeeeee.
My dealer suggested a yellow spring for the primary side . Any one else done this ?
Comments ?
Old Feb 1, 2003 | 09:34 PM
BCLINEHAND's Avatar
Ok It's been a week I guess no one has heard of this.......nyroc any ideas ?
Old Feb 2, 2003 | 01:01 AM
mastrblastr's Avatar
The yellow spring is for EXTREME launch capabilities!! The black secondary spring is a must. It helps considerably with belt life and wear. There are six or seven different springs for your primary clutch. The red spring is the mildest with them getting more extreme from there. I had the red spring in my primary clutch for about a day and I took it out. The red springs engagement is harsh. If you are a rock crawler or technical trail rider, I wouldn't recommend it. If you like the way the silky smooth tranny operates with your stock spring, you won't like the way it engages with the red.
Old Feb 2, 2003 | 02:09 AM
BCLINEHAND's Avatar
Thanks Mastrblastr
Guess I'll hold off on the yellow spring
maybe I'll try out the red one first.
Most of my riding is on forest service roads and powerline
right of ways.
I really appreciate the help.
Old Feb 2, 2003 | 11:26 AM
Check out this site PRIMARY SPRINGS. This will give you some info. Also go HERE . This will give you info on the secondary springs. I wouldn't mind trying the red secondary spring.
Old Feb 2, 2003 | 11:08 PM
tommyboy84's Avatar
If I'm not mistakeing the white primary spring comes stock? Wouldent that make the purple spring the most harsh? If Its thst much more extream than the red,yellow, and the others wouldent it be heard to keep the front end on the ground? I would like to find out witch one gives you the most wheelie ability so I can change to it for roosting arround and back to stock for hunting. Oh and what about the red secondary spring???? Ive never heard of this. What would it do besides make youre belt even tighter thus givening you better take off the the black??
Old Feb 11, 2003 | 11:34 AM
BCLINEHAND's Avatar
picked up the Black spring from my dealer on the weekend and picked up all the pieces I need to make nyrocs spring compressor. Now to (GULP) remove the CVT cover and get to work.
Old Feb 11, 2003 | 11:57 AM
Nemmeh's Avatar
You'll like the black spring, I certainly do. The install isn't very hard and you just need to take ya time and watch your fingers.
Old Feb 11, 2003 | 07:52 PM
BCLINEHAND's Avatar
Mastrblastr,
Got the spring in !!!!!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
From reading the forums I understood that the stock spring is White but..........
When i took my clutch apart the spring in the secondary was yellow
Nowi am a little confused ![img]i/expressions/face-icon-small-confused.gif[/img]
I believe I am in need of some forum therapy [img]i/expressions/face-icon-small-frown.gif[/img]
or mebbe I'll go out and expierience some of that head snappin' accelleration[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 11, 2003 | 08:23 PM
Nightryder888's Avatar
the white is for the prairie 400, the yellow should be in the secondary for the 650
