Had my raptor dyno'd today
Old Jan 25, 2003 | 11:04 PM
weasle's Avatar
Default Had my raptor dyno'd today
I'm running a Trinity Pipe, CFM airbox, Dynojet Stage 2 kit (needles on 4th clip from top, 148/150 mains, stock pilots, and A/F screws 3 turns out)
With the stock tires at 9psi I pulled a max hp of 45.4HP. This was on a dynojet atv/motorcycle dyno
My air/fuel ratio was almost perfect. In the summer I will drop down to a 146/148 setup, but for winter, I've got it dialed in just right. IT was reading just above 14 and curved down to just below 13 in the midrange and about 13.5 at the top. With one set leaner jets I should be btw 14.4-13.6 on A/F ratio. I don't know exactly what the numbers mean, didn't ask the guy, this is just what he told me.
Old Jan 25, 2003 | 11:28 PM
PatsRaptor's Avatar
Congrates thats a sweet number
Old Jan 25, 2003 | 11:37 PM
14mins's Avatar
Patsraptor- did you dyno at FSW's???
Good numbers weasle!!!!
Old Jan 25, 2003 | 11:55 PM
weasle's Avatar
Thanks!
I took your advice and put some 600grit sandpaper to the pipes. It cleaned them right up. I cleaned em up real good, put them on gloves and now they are a solid gold from front to back. They look much better.
Old Jan 26, 2003 | 09:10 PM
AlkyBurninX's Avatar
Guys, what kind of torque are your turning? I have a friend that has papers to back his 90ft/lb claims. He ported the engine hisself so I was wondering if this is about normal or if he found a sweet setup since his hp is lower (around 55 if I remember correctly).
Old Jan 27, 2003 | 09:18 AM
weasle's Avatar
Torque was at 40ft lbs [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 27, 2003 | 10:10 AM
PatsRaptor's Avatar
No Mark I have wheel spacers and would have taken too long o switch over.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 27, 2003 | 03:35 PM
raptor03's Avatar
I did the dyno at 4 stroke wars and i dyno'd at 47 hp with a pipe and jet kit,and a pro design foam filter...
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 12, 2015 09:39 AM
