Is the squeaking normal?
Old Jan 26, 2003 | 11:26 PM
looking's Avatar
Default Is the squeaking normal?
I have a '03 sp 400 it has 100 miles and 20 hours on it. The front end squeaks like an old rocking chair when articulating the front suspension or turning the handlebars. I can't find a grease fitting on the stearing arm pivot point but that is where the noise seems to be coming from. I have read the Polaris removed most of the grease fittings in favor or "permanetly" sealed joints. Any ideas?
Old Jan 27, 2003 | 12:12 AM
OffRder15's Avatar
Could be your springs. Mine squeak too. I just spray some Tri-Flow near the bottom of the springs and it helps. Also could be ball joints if you took that thing through a lot of water and mud. I doubt it though because it's so new.
Old Jan 27, 2003 | 09:47 PM
pest44's Avatar
The squeking is coming from the top of your springs. There is a lower and an upper pivot ball and the squeaking is most likely coming from the lower one. Spraying wd-40 or something like that will temporarily stop it, but it will return. Mine has 3,000 miles on it and started doing it when it was almost new. I've tried several things to stop it and finally found one that works. I cut out pieces of plastic milk jug and placed between the lower pivot ***** and the shock tower. The squeak has been gone for a few hundred miles now. It's easy to do and basically free.
Old Jan 28, 2003 | 07:44 PM
Mudracer300's Avatar
hey pest my scrambler squeaks like crazy i would like to know more about your fix with the milk jugs. the nosie just drives me crazy.
thanks for the help
Old Jan 28, 2003 | 08:30 PM
looking's Avatar
Yes Pest, please explain. Better yet, you know what they say about pics...
Old Jan 28, 2003 | 11:43 PM
jmrpage's Avatar
hello
i sprayed thrust into the inner and outer tierod ends on my scrambler and the noise totally went away .
Old Jan 29, 2003 | 12:14 AM
pest44's Avatar
I don't have any pictures of what I did, but I think I can explain it pretty clearly using the diagram attached to the link below. All I had to do was remove the top nut from the strut (27), which will allow you to remove 26,25, & 24. I then jacked up the front end just high enough to remove the lower pivot ball (19). You only need to jack it up enough to slide the lower pivot ball up and over number 21. I then cut out a piece of round plastic (from the milk jug) just a little larger than the diameter of the pivot ball and then cut a round hole in the middle of the plastic so that the plastic will slide down over number 21. Now the plastic will be between the lower pivot ball and the shock tower. The shock tower is in the left part of the diagram between the numerals 24 & 22. I sure hope this helps out. The link was running slowly, but it would open, so you may need to give it a few seconds.
Squeakstopper
Old Jan 29, 2003 | 04:28 PM
thanks i think i get it ill try it out as soon as i get the time and the wheel studs back in
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Ahtatu
Sep 28, 2015 12:14 PM
exmotocrosser
Sep 26, 2015 08:18 AM
alzgarvin
Sep 11, 2015 08:53 AM
Canamaniac!
Sep 4, 2015 06:44 PM
