ITP Series C on Magnum 325
Old Jan 28, 2003 | 03:59 AM
BarelyLegal's Avatar
Default ITP Series C on Magnum 325
What size ITP wheels do I need to get to run the stock tires on my Magnum 325?
Old Feb 1, 2003 | 10:56 PM
Rockwalker's Avatar
Anyone you talk to will tell you to stick to the original size on the Magnum 325, it just doesn't have the power to handle anything else, one of our club members tried going to a 25" and ended up replacing the rear axle because it twisted and front u-joints . Hazards of an under powered machine.[img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 2, 2003 | 03:56 AM
Ok, so what's the original size of the wheel?
Old Feb 2, 2003 | 01:55 PM
Rockwalker's Avatar
You didn't specify year so I'll give you a couple of years, 2002 Front - 24x8-12, Rear 24x11.5-12, 2003 Front - 24x8-12, Rear 24x11-12. I am waiting for a reply from Polaris to see if the new standard rear tire for 2003 is acceptable on all machines as it is very difficult to find a good aftermarket tire in the 11.5x12 size. Hope this helps you out.
Ride hard, get dirty.
Old Feb 15, 2003 | 04:32 AM
My sig says 2002. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 15, 2003 | 09:38 PM
showmethemud's Avatar
BarelyLegal, the only size that the ITP c-series wheel comes in is a 12x7 with a 4 on 156 bolt pattern. Your rear tire should fit fine but your 24x8-12 front tire might be too narrow for a 7 inch wide wheel. How wide is your stock front wheel? I'm guessing it's a 12x6? It should be stamped some where on the wheel.
Old Feb 16, 2003 | 04:44 AM
Stamped? Cool. I'll go look. If I need to get wider tires I'll do that.
414 is coming first I think...
Old Feb 16, 2003 | 12:52 PM
Rockwalker's Avatar
BarelyLegal
Sorry I'm late in getting back to you, here are the tire sizes that must be on your bike any wider or larger and you are looking at potential axle breakage, bearing or gears blown, the 325 stock can't handle anything else. Nature of the beast. Front 24 x 8-12 Rear 24 x 11.5-12 you can use a 24 x 11-12 on the rear also.
Wide and High will cost you in the end.
Good Luck[img]i/expressions/face-icon-small-smile.gif[/img]
Gwolf228
Feb 18, 2017 01:36 AM
Sep 10, 2015 01:56 AM
Sep 9, 2015 06:57 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
