Are Primary Clutches Interchangeable????
Old Jan 28, 2003 | 10:07 PM
400fnSport's Avatar
Default Are Primary Clutches Interchangeable????
I'm just wondering if a Indy 650 primary clutch can be used on a 400 Polaris motor??
Old Jan 28, 2003 | 10:21 PM
Bubba297's Avatar
It will bolt up to the motor, buuuuuut, it will not work because they are physically bigger than the ATV units. Not only will it not fit inside the cover, if you put one on and tried to go at full throttle long enough, it would try to shift out so far something would break like the belt. So you need to stick with the ATV clutches. The good thing is that you can use any non-ebs clutch, just change the weights and spring.Bubba
Old Jan 28, 2003 | 11:28 PM
400fnSport's Avatar
Thanks Bubba, I've got what looks like a stress crack on the backside of my drive clutch "the side nearest the motor. I thought maybe I could interchange the clutch and use the weights and spring I have now. Thanks for clearing that up.
Old Jan 28, 2003 | 11:47 PM
Bubba297's Avatar
clean it up real good and look at it very carefully. Cast aluminum like that tends to get spots on it that look like cracks, but are part of the casting process. Hopefully it's not. I have 2 clutches on e-bay right now and they already have bids on them. Keep an eye out on them if you need one.Bubba
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
