Carburator Mods?!
Old Apr 12, 2000 | 10:24 AM
valerius's Avatar
Somebody help me out.
I am not sure about how carburator mods work on 4-stroke motors.
Basically;
1) What does the size have to do with performance? i.e. 27mm, 34mm, etc...
2) Is it wise to increase size with a stock motor? Any gains, benefits, pit-falls?
3) Case Study: What if I replaced a 27mm carb with a 34mm carb?
Reason for asking, I need a new carburator for my ATC 250SX. Rather than put a stock carb back on it, I am curious if there is something to gain by swapping for a better set-up. I do plan on modifying the engine at a later date and a K&N filter will be put on real soon.
Thanks.
Old Apr 12, 2000 | 02:27 PM
Air's Avatar
Air
A slightly larger carb will help Honda typically undercarbs their quads. For your application I would try to find a carb from a 300ex. Going too large will cause poor low speed performance. I f you were to add a pipe, cam, and piston a little larger carb would really help.
Old Apr 12, 2000 | 04:47 PM
valerius's Avatar
Air,
What size is a 300ex? What about a 34mm from an ATC 350x?
Thanks.
Old Apr 12, 2000 | 06:04 PM
Mike300EX-99's Avatar
A stock 300EX carb is a 32mm Keihin.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
