need help with tires for 360
Old Jan 29, 2003 | 08:27 PM
billdozer's Avatar
Default need help with tires for 360
i am getting ready to buy some new tires for my 360 im going to get the itp mudlites. ive been thinking about running 26-10-12 on all four rims would this mess up any of my controll or what the reason for buying the same size for all four is that its cheaper i dont want to go with the 25" because im looking for somthing with tread depth if anyone could help i would appreciate it
Old Jan 29, 2003 | 08:58 PM
Zoinks!!!'s Avatar
By going to a 26 from a 25 will not give you enough significant difference. If you are wanting a taller tire go with a 27 but from 25 to 26 you will not gain but a half inch in total highth with the 27 you will gain an inch. Plus just cause its a taller tire does not mean that you get deeper tread depth. If that is your major concern I would stay with the 25 and you will be pleasantly suprised at how well just the mud lite will help.
Old Jan 29, 2003 | 09:13 PM
nyroc's Avatar
Billdozer, it does not hurt to use the same tread on all four for handling, but can make steering harder.
Wider tires make steering harder. I advise against it. Put fat tires on the back and skinny on the front. The back ones need more tread anyway since they have to deal with you spinning them so much more.
Additionally, most tire manufacturers make the skinnier tires just a shade smaller than the fronts, so that you can steer easier in 4x4. If you use all the same size, you may wind up a bit harder to steer (been there and done that). If the front tires a a lot smaller than the back then there is a big drag and the 4x4 shifting system has to take an impact each time you shift into 4x4.
Go with narrow fronts and wider rears. It won't be all that bad to use all the same tires, but I do believe you won't like it as much.
You may not gain a whole lot of ground clearance with 26", but you won't loose much power either so go ahead and get them. You have my permission. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 29, 2003 | 10:58 PM
TeamGrnMojave269's Avatar
I've got 26" Bear Claws on my 360 26x9's up front and 26x12's out back...Their awesome I know your set on getting Mud Lites but you should consider the Bear Claws!!
Old Jan 30, 2003 | 11:31 AM
Uinthas's Avatar
Teamgrn.. Did you loose much power with your 26" Bear Claws?? Do you know how much they weigh?
Old Jan 30, 2003 | 01:36 PM
billdozer's Avatar
i really appreciate evreyones help thankyou master nyroc for giving me permission to go ahead and get them the reason i want the 26"mudlites is that the tread depth is deeper i would go with the 25" but it has the same size tread that i already have with the stock tires i put 25"gators on my prairie 300 4x4 and 2 months later it was stole good thing for atv insurance i would go with the gators again but they remind me of the mudbugs evrey one i ride with has them on their hondas so i dont want to be like them well i appreciate evreyones help i belive i will still buy the mudlites so when i get them i will post a message again
Old Jan 30, 2003 | 10:42 PM
I haven't noticed any power loose at all. I don't know how much they weigh though?? Man they look killer!! I'll post a few pics of them as soon as I can get the bike washed good!
Old Jan 31, 2003 | 06:57 AM
nyroc's Avatar
I emailed KendaUSA asking how much they weighed. They haven't replied back.
I emailed them 3 months ago asking how much the 26x9-12 bearclaw weighed. It was 19 lbs. If I'm not mistaked all bearclaws are 6ply (they are now at least, I don't know if they haven't always been).
Old Jan 31, 2003 | 11:45 AM
Uinthas's Avatar
Those bearclaws look to be a good tire, especially at 6 ply.. I was also considering some Carlisle AT's anyone have any experiece with those tires?? [img]i/expressions/face-icon-small-smile.gif[/img]
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
