Need Help
Old Jan 30, 2003 | 11:25 AM
Wannaride's Avatar
Default Need Help
I have come to a point where I have to replace my oringinal Baja tires. I am undecided what type of tires I should buy. I ride only on hard packed trails and also groomed ski-doo trails in the winter. What is everyones recomendations. ??
Also If I were to change tire size from 20x10x9 and go to a 22x11x9 what should I expect as far as loss of top end, decrease in lower end torque. Should I then go and change gearing? if so, change gearing to what?
Thanks
Old Jan 30, 2003 | 01:11 PM
JMAC650's Avatar
Default Need Help
I would either go with the Pure Sport Bandit's 22x10x9 xc rear and the 23x7x10 xcr in front or the Holeshot's 22x11x9 xct rear and 23x7x10 xct front. If they are for hard pack I would lean more toward the Bandit's, they seem to last a little longer. Prices are about the same on both tires.
Old Jan 30, 2003 | 01:15 PM
Wannaride's Avatar
Default Need Help
JMAC,
I am actually leaning towards the holeshot XCT 22x11x9, I am not sure if I will need to change gearing. have you riding with a 22" tall tire with a stock gearing and stock rpm limit? Best price I have found is $162.00 (C.A.D) plus tax and shipping.
Old Jan 30, 2003 | 01:21 PM
JMAC650's Avatar
Default Need Help
I run the stock gearing and it works great. It is like the DS was designed for 22's. Just remember the holeshot is a great tire but the do wear faster.
Old Jan 30, 2003 | 01:25 PM
Wannaride's Avatar
Default Need Help
like faster then the ohtsu's that came stock with the bike?? hope not. Just found a better price 145.00 + tax no shipping.
Who make the Bandits?? Do you have a link or a web address so I can view them?
Old Jan 30, 2003 | 01:35 PM
NYds650's Avatar
Default Need Help
I had the bandits they last forever but they have pour traction, I also ride on hard pack and rock and I now run razors they gave me much better traction. I'am going to try hole shot xct next.
Old Jan 30, 2003 | 01:36 PM
02BAJA's Avatar
Default Need Help
I went with 23" Razrs in the front and 22" Razrs for the rear. I went with the bigger size for more ground clearance. You can never have enough of that on the trails. I have been running them since I bought the bike new last Feb. They are wearing very, very well. I still have stock gearing. Didnt loose that much low end. And with a taller tire, you get more top speed. Holeshots wear very fast on hard packed dirt. That mainly all I run. The Razrs must be a harder compound. I am very pleased with them.
Wannaride's Avatar
Default Need Help
NYDS650,
what gearing do you run, and is your DS stock??
Old Jan 30, 2003 | 02:39 PM
Wannaride's Avatar
Default Need Help
02Baja,
just to be sure, you are refering to the 4 ply Razr's no the Razr's 2 which are 6 ply. Just want to stay away from a puncture prone tire.
Old Jan 30, 2003 | 03:23 PM
02BAJA's Avatar
Default Need Help
Originally posted by: Wannaride
02Baja,
4 Ply. I still havent had a puncture. I ride a lot!
