polaris belt please help
Old Jan 30, 2003 | 07:28 PM
hannahj's Avatar
Default polaris belt please help
I just bought a goodyear belt its alot thicker than the stock and we put it on and when ever we went in drive i never hit the gas and my 4wheeler would move it keep moving and did the same in reverse i let it warm up for 5 minutes but keep on doing it i have a scrambler 500 thanks
Old Jan 30, 2003 | 07:59 PM
highwayman's Avatar
I think you answered your own question the belt is thicker so the clutch is grabbing the belt at idle . you could lower you the idle or the belt might wear down so it does't engage early. The third option is to buy a stock belt or one with same dimenions as stock.
Old Jan 30, 2003 | 08:50 PM
Bubba297's Avatar
The original blet was worn down some, so that would help the problem. Different belts from different castings have different lengths too. It might not be much, but enough to cause the problem. That is why the secondary clutch is adjustable. You need to check belt deflection and probably add a shim to the secondary.Bubba
Old Jan 30, 2003 | 09:15 PM
Alpine2's Avatar
Don't worry its just the powerstreak belts they fit a little tighter than the polaris ones it is normal mine did this for about a few hours of hard ridin but it will break in just fine.
you should use an agressive clutch kit with this belt because it is a harder compound.......
Hope this helps
Old Jan 30, 2003 | 11:39 PM
hannahj's Avatar
and i forget to add this but with the belt on it is also hard to put it in neutral when im in drive and in reverse
Old Jan 31, 2003 | 12:19 AM
2manytoys's Avatar
It is hard to put in neutral because your secondary is turning faster than it normally does to shift. Adding the shim should take care of the problem. It is normal for some bikes to creep after a new belt. It is a good belt and what you have is not a problem, but it is an adjustment that you have to make.
Old Jan 31, 2003 | 11:00 AM
maybemeamI's Avatar
what is a shim
Old Jan 31, 2003 | 12:01 PM
Bubba297's Avatar
Just a thin metal shim that goes between the secondary sheave halves. As you add or remove them, it changes how far the belt rides in or out and changes the deflection.BUbba
Old Jan 31, 2003 | 04:03 PM
vig's Avatar
vig
I bought an aftermarket belt for my scrambler and it did the same thing as yours. I took it back and bought a polaris belt, fit perfect. Some things ya just gotta get from the dealer.
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
