Rawhides to soft
Old Jan 31, 2003 | 02:20 PM
BuckinHO's Avatar
Default Rawhides to soft
300 miles and I already see a big tread wear and my running is in words or dirt. Surt they ride nice but there not going to last so what would be a good replacement something that lasts, but still soaks bumps..............[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 31, 2003 | 02:53 PM
polarisman3's Avatar
well I have a 2002 magnum 500 with 500 miles and you cant even tell the tires have been used......there is a few cuts in the tread but other than that it hasent worn yet.....I only drive in the fields so.....I think they are excellent tires all around...
Old Jan 31, 2003 | 03:12 PM
AtvNutPolaris's Avatar
I have 15pds in the rear and 25 in the front of my rawhides. I have gotton 650 miles so far and they have over half the tread left.
O yea did I mention that 350 of them miles are down the middle of the road traveling 40-60mph.
Old Jan 31, 2003 | 07:24 PM
Northstar2's Avatar
I hope you wear a helmet when you ride down the middle of the road with your tires overinflated by 300% to 500%. I hope your kidding, if not you are going to crash eventually.
I run the CORRECT pressure in mine, I pound them unmercifully in rocks and mud, I've done burnouts on pavement and I have better than three quarters of the original tread left, just turned 700 miles. I think the Rawhides are anything but soft. If that is your complaint, I wouldn't even know where to point you for a replacement.
Old Jan 31, 2003 | 09:43 PM
jett's Avatar
Just a suggestion but you may want to look at the Dirt Devils. Had them on P650 to replace the Duncraps. They made a world of difference, I could go where the sp700 could once I swapped rubbers.
They are not a light tire by any means, but well built, with a good tread pattern for trail riding. Check them out for yourself.
Old Jan 31, 2003 | 10:22 PM
I will replace my rawhides with bearclaws, they do good on the road, don't wear bad at all.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
lancemll88
Sep 5, 2015 03:16 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
hugemoth
Jun 4, 2015 02:56 AM
