which clutch kit should i get
Old Jan 31, 2003 | 06:46 PM
hannahj's Avatar
Default which clutch kit should i get
should i get the hotseat, aaen, or hpd which one do you think is the best i have a white brothers pipe and a K&N filter i would like to do wheelies when im goin like 5 or 10 mph will this do that. Im also going to be gettin a 160 jet
Old Jan 31, 2003 | 08:18 PM
2manytoys's Avatar
Get a Heelclicker kit or the HPD agressive kit. The Heelclicker will get more HP to the rear wheels.Almost no slippage with this kit but as for HPD agressive kit it is more of a performance kit. Better low end, better upshift and some added top end.
Old Jan 31, 2003 | 11:34 PM
hannahj's Avatar
is the heelclicker the hotseat one and so mostly all i want is bottem end power and some midrange so should i got with the hpd
Old Jan 31, 2003 | 11:58 PM
2manytoys's Avatar
Yes the HPD will give you the most improved bottom and midrange. You can get an agressive kit for $90.oo. This will not include the helix but I dont think it is needed for your use.
Old Feb 1, 2003 | 12:13 AM
hannahj's Avatar
on the site they only make it for the 400s and 250s. So does the helix help that much or should i just order it all separate
Old Feb 1, 2003 | 12:49 AM
BigBadScrambler's Avatar
They make it for the 500. I just ordered my HPD agressive clutch kit for $155 through Rick Ritter.
Old Feb 1, 2003 | 10:04 AM
VSchlitz's Avatar
Is the Heelclicker clutch easy to install. I have a '03 SP700, is it fairly simple to do? Any special tools and/or mechanical ability, price, etc.
Old Feb 1, 2003 | 10:31 AM
2manytoys's Avatar
Yes the heelclicker is easy. The only difficult part would be the secondary. If you have never done one before or you are not mechanicly inclined then I would let the dealer do it. It really is not hard thouhg.
Old Feb 1, 2003 | 11:53 AM
medicdave's Avatar
I put a Heelclicker on a few weeks ago. I really helped my performance and cured my belt slipping. The only difficult thing about a Heelclicker is the shim they use on the primary on the SP700. The spider needs to be removed which requires a special tool which your dealer will have. You will be able to change springs or weights at any other time on your own.
Old Feb 1, 2003 | 01:07 PM
VSchlitz's Avatar
Any idea the cost for the spider removal tool? Any one know the part number?
