425 magnum stuck in forward gear
Old Feb 4, 2003 | 12:47 AM
nedrah's Avatar
Default 425 magnum stuck in forward gear
I have a 95 polaris magnum 425.. It is stuck in forward gear and I can not shift it to neutral even with the engine off. Any suggestions. I have been hearing a low clicking sound lately.
Old Feb 4, 2003 | 12:49 AM
biggin's Avatar
Check your linkage.
Old Feb 4, 2003 | 01:04 AM
TLDPredator's Avatar
I had the same problem when plowing with my SP335 a couple weeks after the warrenty was over. Worst part is it was stuck in the snow. When I got it out and to the garage I diconnected the shift rods and moved them around. Then I started to take the shift er box apart till I saw the springs and things inside and decided there was no way I was dealing with all that without a manual. When I put it back together it worked again. Never had the problem since.
Hope I was some help.
Old Feb 4, 2003 | 07:47 AM
ftwflh's Avatar
Take the lid off of the shifter and clean the gunk out of it and put in new oil.I bet it has been out of shifter oil for awhile.Use a 10w40 oil.
Old Feb 17, 2003 | 11:44 AM
nedrah's Avatar
problem fixed thanks guys...no oil !!!!
Old Sep 23, 2003 | 09:47 PM
muddymagnum's Avatar
ftwflt, im just curious what do u mean by take the lid off the shifter, how do u do that & how much oil should there be in there. do u mean the case that the shifter is connected to.
man i realy need a manual - Its on backorder .I am looking for a used one.
Old Sep 24, 2003 | 07:50 AM
ftwflh's Avatar
Its the black box that the shifterr handle is attached to.Just take the screws out lift the shifter out and there should be about half full of oil(any motor oiil)whatch out for the springs.
heath legg
Jul 24, 2015 01:01 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
sara durrant
Jul 6, 2015 05:32 PM
