warn winch
Old Feb 4, 2003 | 10:22 PM
Probe's Avatar
Default warn winch
Just purchaced a warn 2000. (polaris) Where do you recommend i install the solinoid on my 500 ho. Also where is a good place for the in/out switch? [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Feb 4, 2003 | 10:46 PM
500DUSE's Avatar
Default warn winch
I did away wiyh my solinoid.
The solinoid seemed to be the weak link on mine.
Went through 2 of them in a year.
As for the switch,before you go installing it
you might want to think about getting the rocker(handle bar mounted)
Well worth the extra $50
If you keep it switch,
the left hand side of the rack would work.
Old Feb 5, 2003 | 12:33 AM
TheWayOut's Avatar
Default warn winch
I bought the same winch. I put the solinoid in the dry box.(put a little silicone on the nuts) The on/off switch I put into the side of the head light pod and wired my power into the 12v cig lighter. The rocker switch is an absolute must, spend the $50 it is well spent.
2000 Sportsman 500
Double tube bumpers
2000lb Warn/ rocker switch
Old Feb 5, 2003 | 09:11 PM
Firedawg's Avatar
Default warn winch
I also put my solinoid in the box under the seat.Have not had any problems with it going out though. If you use the butterfly switch put it on the left side of the rack ( if you choose the rack as a mounting location). I put mine on the right. Not so good. If you lean under the handlebar to get to it you tend to bump the throttle with your shoulder. I plan on getting a rocker switch as soon as a can afford one.
Old Feb 6, 2003 | 09:50 PM
fullthrottle's Avatar
Default warn winch
500DUCE,
Can you explain to me the wire hook-up without the solinoid. I have been having the same problem as you in regards to the solinoid burning out. I replaced it with a 1973 ford f150 sol and burnt that one too. One other thing to add; I have a on/ off toggle hook up. My solinoid is mounted near battery on the fender bracket.
fullthrottle
2000 xplor 400 4x4
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
