I need speed help with 400EX
Old Feb 6, 2003 | 05:25 PM
LTearnhardt's Avatar
Default I need speed help with 400EX
just need to know what kind of parts i can get to make my 400ex faster quickly.
Old Feb 6, 2003 | 06:26 PM
Quadfather's Avatar
Depends on how much money you want to spend. You can go the budget route, with a slip on pipe, and a high flow air filter plus jetting. Or to see big gains, you can do a higher compression piston and cam, plus the slip on and filter.
Old Feb 7, 2003 | 08:21 AM
adamwn's Avatar
Or if you just care about how many miles per hour you can go, go up a tooth on the front sprocket.
Old Feb 7, 2003 | 11:07 AM
How do u adjust the sprocket?
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 7, 2003 | 02:35 PM
Quadfather's Avatar
You dont adjust it, you buy a new one and install it. Very cheap, and easy to do.
Old Feb 7, 2003 | 10:10 PM
quadwarrior02's Avatar
youll start off a bit slower((a little bitty) nd then youll fly in the high mph
Old Feb 7, 2003 | 10:13 PM
or visa versa (go down one tooth to take off faster)
Old Feb 8, 2003 | 05:28 AM
adamwn's Avatar
Stock front sprocket size is 15 tooth, go up to 16 for a higher top speed (more miles per hour) or go down to 14 for more acceleration but less top speed. We're not talking huge differences but maybe around 10-15 miles per hour faster top speed with the 16 tooth, that would put you in the mid 80's if I am not mistaken. But it will take a little longer to get going that fast because you loose a bit of acceleration.
Old Feb 8, 2003 | 11:36 AM
chad400ex's Avatar
I may be wrong, but putting in the 16 tooth front sprocket also requires you to remove your case saver, (or grind the stock one down until it is really thin)... I wouldn't do that. If you want a little more speed without loosing as much bottom end, get a 36 tooth rear sprocket. I guess it depends on what type of riding you do, but just changing the sprockets isn't the answer. It helps when fine tuning your bike after doing different mods to it. I personally run a 14 tooth front sprocket, and it is perfect for me (but I don't drag race). It does the job for riding in the dunes, hillclimbing, and general fast trail riding. I'm actually considering dropping the rear sprocket down to a 36 tooth to gain back a little speed on the top end, because with the 14 tooth front, you will lose about 5-7 mph on the top end, but you accellerate like crazy.
Old Feb 8, 2003 | 02:17 PM
thanks everbody
