250r longrod advantages?
Old Feb 8, 2003 | 01:59 PM
sweetcorn's Avatar
Default 250r longrod advantages?
Does anyone know the advantages or disadvantages of running a long rod instead of the stock in a 85 250r motor? do they put out more topend? thanks for the read
Old Feb 8, 2003 | 02:34 PM
theHulkamaniac's Avatar
The reasons I heard honda went to the long rod were:
1) More reliable? I think my 86' is pretty reliable, so I am not to sure on that one.
2) It was supposed to make the power less peaky. Just to smooth out the power-band.
Old Feb 8, 2003 | 02:52 PM
Spinks250r's Avatar
A big reson is price. When I replaced my crank the short rod was quite a bit more costly than the long rod. Just remember that you have to use a spacer plate if you use the long rod and an '86 style piston.
Old Feb 8, 2003 | 06:59 PM
DaBeechMan's Avatar
arguably the long rods put out more power/torque then the short rods, but they dont revv as well as the short rods.
Old Feb 12, 2003 | 09:17 PM
sweetcorn's Avatar
that clears some things up, thanks for the replies
Old Feb 12, 2003 | 09:23 PM
DaBeechMan's Avatar
Im not allowed to help any of you guys now. DevilMan says im a know-it-all. So he can help you from now on.
Old Feb 12, 2003 | 11:05 PM
2fun's Avatar
LOL!![img]i/expressions/face-icon-small-happy.gif[/img]
Yeah, you "know it all"![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Feb 12, 2003 | 11:17 PM
DaBeechMan's Avatar
awww LoL
Old Feb 13, 2003 | 04:32 AM
DaBeechMan's Avatar
"Practical experience tells me that a shorter rod will out perform a longer rod.....except in longivity!
In my opinion, the difference seems to be more in "when" the piston speed is different.
The long rod does have more dwell time around TDC, and that probably does translate into a more efficient burn of the fuel charge. The push is going to be through a less servere rod angle, so it will be easier on the piston and cylinder wall during the powerstroke. The fact that the long rod moves slower in the upper quadrant, should also give you a more efficient burn, because you will have more time for the burn to happen, and more time to translate that burn into rotational force upon the crankshaft. The down side of the long rod seems to come in because it is faster during the lower quadrants than a short rod. Because it started slower at the top, it must move faster at the bottom, when the fuel is being transfered up into the bore area. It is not very easy to see, but the piston will be over 1/2 way down the cylinder when the crank is at 90 degrees, and this is where it starts getting faster. As you may have noticed, the faster speed at BDC is quite noticable, and this is when we are transfering the charge.I believe we will find that the transfer Timing Area (TA) is less with a long rod motor, due to the fact that we have the same size ports....but less time for them to get used! The slow speed in the upper quadrant will most likely hurt performance when the charge is getting compressed, it should be more benificial to compress the charge faster. This may be part of the reason a long rod motor seems somewhat "lazy" or "soft" off of the bottom end."
This should explain it better
Old Feb 13, 2003 | 12:57 PM
Duneaddict's Avatar
Very Well Said! (you know-it-all [img]i/expressions/face-icon-small-wink.gif[/img] )LOL!!!
