Honda rancher gas leak
Old Feb 9, 2003 | 02:01 PM
delta221's Avatar
Default Honda rancher gas leak
I have a 2000 honda rancher. I noticed yesterday that a steady drip of gas was coming from a tube under my atv. I think that is the over flow tube. My entire tank of gas leak out of the tube over night. It does stop when i turn the gas off. But starts dripping again when I turn the gas on. What is causing it to do this? Thanks
Old Feb 9, 2003 | 09:19 PM
RedRancher's Avatar
delta221,
Sounds to me like the float in your carburetor’s bowl is faulty. Let me explain...there is a bowl on the bottom of your carburetor, this bowl is a holding tank for the gas that the carb is about to use. Since this bowl is below your gas tank gravity will work to constantly pull fuel form you tank and feed your bowl through an opening at the top of the bowl. However, to avoid the bowl from filling too much and overflowing (through the overflow hose) a little ball inside this bowl floats on the surface of the fuel that's inside. As the level of fuel increases so to does the height of the float, eventually the level of fuel inside your bowl fills all-the-way-up, which forces the float to rise and finally plug the opening in the top of the bowl where the fuel is being dispensed from. If the float is stuck it will not rise as the fuel in your bowl does, therefore the opening will never get plugged by the float and the gas will continuously pour into your carb bowl and overflow out the overflow hose.
I will explain how to fix after dinner.
Old Feb 10, 2003 | 12:07 AM
delta221's Avatar
I appreciate it!!
Old Feb 10, 2003 | 03:36 PM
action450s's Avatar
As a quick fix, give the carb a couple taps with a small hammer. This should unstick the float/nedle valve. This isn't a permanent fix, cleaning the carb would most likely solve your problem. You may also have to replase the float.needle valve assembly.
Nondem
Feb 22, 2020 12:20 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
