Question about bore size options...
Old Feb 10, 2003 | 10:16 AM
HillbillyDS's Avatar
Default Question about bore size options...
I'm ready to order a larger bore piston (probably from Sam Coe) and I see he offers a 2mm and 3mm oversize. I plan to have US Chrome bore & replate my cylinder but my question is this: Is there anything to be leary of or concerned about, I think I remember reading something about piston skirt clearance issues or something. Sam Coe's website also says that I will need different valve springs with this piston, why? I plan to install a set of Web cams without the shim under bucket conversion because I'm not going with a radical grind, just the heavier springs. I simply need to know what to look out for in advance if anything. Many thanks in advance!
Old Feb 10, 2003 | 10:33 AM
SANDMAN430's Avatar
gary at tvi does a lot of these, try him. 503-648-1254
Old Feb 10, 2003 | 12:03 PM
DuneMe's Avatar
Are you looking to go with the full Same Coe kit? (Stroke too?)
After being at 4 Sroke Wars and looking at what MajorEcho had to do to take care of clearance issues with the piston and the head, I would not purchase the Sam Coe kit (bore and stroke.) Major is an extremely knowledgeable and detail oriented person. I don't like the idea of putting clay in my motor to check for clearance issues. I think this should be done by the guys putting the kits together.
As for a 680 kit. That could be done for your DS without too much difficulty. Sounds like you have someone that could bore your cylinder out to 102mm. Team Pami offers a 102mm piston (with rings) in both 11:1 compression and 12:1 compression (Gary, TVI or Team Pami direct can help you with it.) You will also need a gasket (head and base) for the kit (again Team Pami has it.) The other thing I would suggest is the heavy duty stud bolts and nuts (Pami or TVI.)
As for the valve springs, I run the shim under bucket with mild cams. I think Marky had a set of shims shatter on him (shim over bucket) and cause some damage. It has been a while, could have been someone else.
Old Feb 10, 2003 | 02:23 PM
I just got off the phone with Gary at TVI & I feel it would be in my best interest to go through him.. He took over an hour with me to determine my exact needs & this guy REALLY knows DS's. I'll be getting some funds together & getting back with him shortly. If anyone else out there is looking at some motorwork, definitely give Gary a call before you make your decision!
Old Feb 10, 2003 | 07:20 PM
Batoutahell's Avatar
I have to say that I really enjoyed talking with Gary while at FSW. He is a nice guy, and I would have no trouble doing business with him. Unfortunately my banshee is getting all of the money that my wife leaves me lately.
Bat
Old Feb 10, 2003 | 07:24 PM
DuneMe's Avatar
Well, don't leave us hanging Hillbilly!!! What are you going to do?
Old Feb 10, 2003 | 10:14 PM
SANDMAN430's Avatar
i do have to say gary has a passion for the ds and shares what he knows, and it seems like he works hard to bring new things to the market for the ds, i know he came through for me on some clutch springs when pami wasn't easy to get. and when i went carb mount he made sure i got the two other little filters that i would need (i was clueless and thought he had sent some nonsence until i took the stuff apart and realized oh i will need those. when i called to get a head gasket, they called him at fsw to find out what i needed, and he called back , i thought that was some service. and he is always willing to chat and give advice. [img]i/expressions/face-icon-small-smile.gif[/img]
1986Vmax540
Jul 9, 2021 09:53 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
toonces
Aug 5, 2015 05:55 PM
Schneider
Jul 24, 2015 05:05 PM
