Does anyone make a 520 chain and spockets for a DS???
Old Feb 10, 2003 | 03:14 PM
biggerisbetter's Avatar
Default Does anyone make a 520 chain and spockets for a DS???
I would like to know
thankx.
Biggerisbetter.
Old Feb 10, 2003 | 03:24 PM
KMDuner's Avatar
You trying to shed some pounds there Bigger.
Old Feb 10, 2003 | 03:39 PM
quadzilla499's Avatar
Yea they make one if you will change your swing arm over to a banshee. Hey I have a eight over with the round housing. Talk to DSmike about it. It looks good on there bikes.
Old Feb 10, 2003 | 04:02 PM
I need to stay with my axle and stuff, instead of buying everything for a banshee to convert it over. I thought I read some place that someone made 520 sprockets for the DS. Surely someone makes them.
KMduner,
With all the people around here going "high" this and "larger" that.[img]i/expressions/face-icon-small-wink.gif[/img] I need all the help I can get.
Well, actually Dsmike is having a +4 swingarm made for me, and I thought the 530 chain would be pretty heavy made even longer, so I was checking on the lighter stuff.
Biggerisbetter.
Old Feb 10, 2003 | 04:30 PM
TheSorb's Avatar
Don't be too sure biggerisbetter. I've been unable to find a steel rear sprocket for the DS that's any larger than stock (40-tooth). There are lots of aluminum ones, but I need a STEEL 43-tooth sprocket. It's unbelievable but true![img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-frown.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 10, 2003 | 04:44 PM
Hightower's Avatar
I know you can get steel front and aluminum rear in 520 width, but don't remember who makes it. I read it in an article about a blue project quad in one of the mags about a year ago. It said going to the 520 and aluminum rear shed like 1.5lbs. Doesn't seem like much considering, but every little bit can help.
I looked up the stock DID 530 chain in the dennis kirk bike catalog - tensil strength difference from it to 520 was not enough to make me care. Pitch is the same, its just wider so it doesn't wear as fast. If I can get steel rears in 520 one day, then I'll convert when my stock wears out, if ever, to save money and weight at the same time.
Old Feb 10, 2003 | 05:01 PM
SANDMAN430's Avatar
the blue ds was a alba project and they did go with a 520 chain, so you might check to see where they got there stuff.
Old Feb 10, 2003 | 05:39 PM
Thanks guys,
Now another question.
What do you guys use to clean your chain?? and can I add links to the stock chain??
Bigger.
Old Feb 10, 2003 | 05:50 PM
dsmike's Avatar
REX my buddy is wanting a +8 swingarm for a shee. how much do you want for it? is it a light weight swingarm?
Old Feb 10, 2003 | 08:18 PM
It is made out of chromoly. I traded a guy for a frame. You might know the guy from LS he runs around with Rodney Ogden. He builds swing arms. His name is Greg Beauchamp. Also how do I get a pic of my bike by name like yours. Hey bigger I have a axle and hubs also for sale also got the brake rotor hub. the only thing I do not have is a carrier or the sprocket hub. Will make a good deal on a 6 over swing arm that runs the stock carrier.
