86 Honda 200x clutch removal "Please Help"
Old Feb 12, 2003 | 08:16 PM
FISHBAG's Avatar
Default 86 Honda 200x clutch removal "Please Help"
I am trying to remove the clutch on my 1986 200x, can anyone tell me how to remove the clutch! I have the engine cover off and can not loosen the bolt that holds on the clutch on. Is there a special tool for this?
There is some type of pully/disc that is on the left side of the clutch, does that need to be removed?
Please help
Desperate in NY!!!!!
Old Feb 12, 2003 | 08:39 PM
RideRed420's Avatar
you looking for a 200x motor??????
hint hint........
Old Feb 13, 2003 | 12:46 AM
mojave300ex's Avatar
You take the cover off, you have already done. Now take out the 4 bolts that hold the springs on and pressure plate now you can slide out all of the clutch plates. I'm not sure on the clutch bolt I know on my YZ80 the clutch bolt had backwards threads that could be your problem, you shouldn't need a puller it's not on a tapered shaft
Nondem
Feb 22, 2020 12:20 PM
Scottma518
Jul 16, 2015 09:19 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
200es
Jul 10, 2015 09:09 AM
