banshee jetting at 3500 ft
Old Apr 16, 2000 | 01:05 AM
peewee's Avatar
my banshee is 3 weeks old, i put the pro flow with a k and n filter on. came with 200 main jets. seems foul the plub in first gear wont wind up then clears up. 32 to 1 mix . when going up a hill im leaving a good trail of smoke. plugs on the most part look dark. i dont want to mess the machine up so any help would be great.
Old Apr 16, 2000 | 10:41 AM
Dune_Scooter's Avatar
your situation is kind of odd. Usually changing to a better breathing filter will do the opposite. It is generally a bit on the lean side. Did you over oil the filter? It is possible to over do it with a K&N. It will pull the oil through the carbs until it dries up a bit. Ive had this prob too. You might also want to make an air screw adjustment. Might need to back them out just a bit.
Old Apr 20, 2000 | 03:25 PM
rweissen's Avatar
How did you remedy an over oiled k&n air filter? It eventually dried up a bit? I would assume the excess oil would be sucked into the carbs and burned.
Rob
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
