Jetting
Old Feb 17, 2003 | 12:02 AM
Armor's Avatar
Default Jetting
I installed a dynoport pipe and in order to make it run well at low rpm, I had to lower the needle two notches so I'm in the first notche ? Is it normal or common ? I run at the sea level, my main jet is a 260. I also tried a much smaller pilot jet and it did not help... Am I the only one among all the guys who have modifed 400 to make the mix poorer with a tuned pipe ???
Old Feb 17, 2003 | 10:38 AM
2manytoys's Avatar
Default Jetting
Looks like your main jet is way to big. If you are lowering the clip it seems that you are running very rich. Put in a smaller jet and then you can raise the clip again. Dynoport is not the best of pipes to put on a Polaris.
Old Feb 17, 2003 | 12:24 PM
hannahj's Avatar
Default Jetting
260 i think would be way to big 2 im running a 160 with mine and i have a whitebros and K&N it works great
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
