Sprocket help please
Old Feb 17, 2003 | 05:57 PM
Spaceout02's Avatar
Default Sprocket help please
I am confused as heck when it comes to sprockets.
What do you get if you go smaller in front and larger in the rear. Or dont you ever change both at the same time. Can somebody tell me all the possible combos and what you get for performance be it low or top end. Thanks!
Old Feb 17, 2003 | 06:16 PM
GE4x4's Avatar
If you go smaller in the front, you will be geared lower, thus loose top speed. Going larger in the rear will also gear you lower like the front, however, going up 3 teeth in the rear is like going down 1 tooth in the front. So by going bigger in the rear, you can do it in smaller jumps. Then if you do it the other way around, bigger in the front or smaller in the rear, you will be geared higher, thus gaining more top speed, but lose bottom end.
Old Feb 17, 2003 | 10:41 PM
RAZOR13's Avatar
GE4X4 is right on!!!!!!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 18, 2003 | 04:00 AM
RoostItUp's Avatar
Check out this site Gearing Explained It's very helpful!
Old Feb 18, 2003 | 10:55 AM
trapperb1's Avatar
Here's a chart that will show you what your gear ratios are with any combination of sprockets/gears. Hope this helps. . . .
http://www.sidewindersprockets.com/images/ratioa.gif
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
