Moto Speed MAP
Old Feb 21, 2003 | 01:00 PM
LapTraff1c's Avatar
Default Moto Speed MAP
I understand there is a Moto speed MAP out that uses the bottom end from a Moto and speed map for the top.
Anyone using this?
Where can I find the file?
Old Feb 21, 2003 | 02:05 PM
MadeMan's Avatar
does the moto have a weak top end or something? what's the deal?
Old Feb 21, 2003 | 02:07 PM
LapTraff1c's Avatar
I dont know, I havent tried that Map, from what I understand the sped has a better top end so someone married the two maps. I think Dubya1 knows a bit more about it
Old Feb 21, 2003 | 04:34 PM
jcv400ex's Avatar
There's no way to "marry" two maps or anything like that. They would have to modify the current fuel parameters of a map to reflect another map....1986ATC can explain it better.
Old Feb 21, 2003 | 04:43 PM
LapTraff1c's Avatar
I got off another board where you can download the MAP. 'Marry' may not have been the best term, but I didnt know a better way to describe it. The MAP from what I understand uses the fuel parameters for the Moto map up to, I believe, 7400 RPM then uses the fuel parameters from the speed map. Supposedly taking the best of both?
It was apparently made by Gabe (atc250r)
Old Feb 21, 2003 | 05:11 PM
1986atc250r's Avatar
Yes, that is a map I made by special request...
It is available for download from cannondaler.com or on the Cannondale Yahoo email group
It is a moto basemap that switches to Speed mappings around 8000 RPM (can't remeber the exact RPM).
If anyone needs the exact RPM of the switchover, I can look at it and figure it out.
Old Feb 21, 2003 | 05:17 PM
DuneDevil's Avatar
I have used this map.
On the dyno with a filter and exhaust, it produced 43.8 hp.
On the dunes, It was great! I would recomend it to just about anyone.
DuneDevil
Old Feb 21, 2003 | 05:29 PM
Dune Devil, I saw a dyno run with 45 HP using my map, only they richened it a bit by using the injector size parameter in the M&D kit. Something to play with....
Old Feb 21, 2003 | 05:41 PM
LapTraff1c's Avatar
Thanks for clarifying that [img]i/expressions/face-icon-small-smile.gif[/img]
What are the significant characteristics of the Traction maps on the candaler page, I know that Dubya made them, I just didnt know if you knew the differences and how they performed?
Old Feb 21, 2003 | 05:45 PM
DuneDevil's Avatar
That is a thought........
How much can the map be "richened up"? It would be fun to play with some "liquid oxygen" in the fuel to see if I could break the 50hp mark.
Just kinda wish I had a Dyno around here.
Anyone in KC know of a dyno.
DuneDevil
