What is the best winch for the Honda Foreman 450ES
Old Feb 21, 2003 | 06:59 PM
SamsondaleNY's Avatar
Default What is the best winch for the Honda Foreman 450ES
Hello,
Looking for some help on whats the best winch for my Honda Foreman 450ES. Any suggestions?
Thanks,
Old Feb 22, 2003 | 05:41 AM
swampdonkeykiller's Avatar
Warn 2500lb. It is easily installed with the appropriate mounting kit, is fairly trouble free, parts are rather inexpensive and readily available, and it has lots of ***** to pull a 500+ lb quad. I find the 2000lb warns to work also, but they come with a poorer switch to control them and the better switch for the 2500lb is worth the extra money.
Old Feb 24, 2003 | 03:05 PM
action450s's Avatar
If the choice is between the 2000 and 2500 lb winch, go with the 2500, way better value, its the same winch, only the 2500 has a better solenoid, and switch setup.
If money is no object go for the new warn 3000 lb. Bigger is always better!!!
Old Feb 24, 2003 | 03:58 PM
Thanks for the information.
Regards,
Old Apr 5, 2003 | 09:36 PM
ho500sportsman's Avatar
the best winch for a honda is the biggest one you can find because you would get stuck so much with 3 wheel drive no ground clearance.A friend off mine has one and it gets stuck all the dam time.I told him the next time we go out it will be $5 a tow lets say i made a lot of money that trip.
greg74
Sep 10, 2019 03:03 PM
bigred20653
Aug 31, 2015 12:41 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
