SP700 Tranny Fluid Change
Old Feb 22, 2003 | 07:28 AM
02SP700's Avatar
Default SP700 Tranny Fluid Change
I have changed the tranny fluid twice now on my 2002 SP700 after it took a swim, and both times, when I take the drain plug off, the tranny fluid will just drip out very slowly. I need to leave the drain plug off overnight for all the fluid to drain out. I have the fill plug removed when the drain plug is off to prevent a vacuum.
Has anyone else changed the tranny fluid? I run Mobil 1 gear lube in it, and it sits in a heated garage. I even tried running it with the rear wheels off the ground to help drain it.
Is this normal?
John
Old Feb 22, 2003 | 08:43 AM
Bill35's Avatar
Mine drians slow to but pull your dip stick out while your draining it that well help.....you get an air lock with the stick still in....
Old Feb 22, 2003 | 12:16 PM
02SP700's Avatar
The SP700 does not have a dipstick, only a fill plug.
Everything did drain out overnight, so I guess it just takes a while.
John
Old Feb 22, 2003 | 06:08 PM
Bill35's Avatar
Well ok but my sportman700 02 has a dip stick on the left side.It says engine oil lock when fliped down it lock so no water can get in....
Old Feb 22, 2003 | 06:11 PM
Bill35's Avatar
sorry I thought you were talking about the oil I got to thinking about it....silly me
Old Feb 22, 2003 | 06:12 PM
PolarisPower500's Avatar
Hey Bill, looks like you live about 60 miles from me. Where do you ride? Will you be at the St Joe ride on April 5-6?
Old Feb 22, 2003 | 09:32 PM
Bill35's Avatar
Hi polarispower mostly I just ride around my land up near troy missouri theres alot of nice creeks up there sometimes I go to fingerslake.Why whats going on at st.joe? I didnt know anything about it.Ive never been there is it nice?...Bill
Old Mar 22, 2003 | 04:38 PM
02SP700's Avatar
See the link below for a picture of my ATV under water.
http://forums.atvconnection.com/mess...ighlight_key=y
John
Old Mar 26, 2003 | 08:51 AM
bayou65347's Avatar
Bill,we have put together a ride at St.Joe State Park down at Park hills .April 5th and 6th.Check out Missouri Spring Ride under Places to ride forum.
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
