glowing headpipe on 650
Old Feb 25, 2003 | 09:07 PM
gt650's Avatar
Default glowing headpipe on 650
i have noticed on my 650 prairie that the headpipe turns red when running throttle up to say 3000 rpm's in neutral for about 1 minute, my friend has 2 prairie 650's they both do it, i'm wondering what you all think is the problem if there is one, maybe its normal i don't know,appreciate any input
Old Feb 25, 2003 | 09:19 PM
RPM's Avatar
RPM
In an automobile, a glowing red header tube is caused by a Lean condition. But at a sustained 3000 rpm I would expect it. When I purchased my KFX400, the service manager told me that because of the fact that they are using thinner material (In the case of the KFX, I believe Stainless, I may be wrong.) I should expect it to turn red under use.
I may be wrong, but I wouldn't worry about it, especialy if it doesn't seem to be uncomon among you and your friends 650's.
Old Feb 25, 2003 | 10:16 PM
Nightryder888's Avatar
it only happens to me when i dont ride it for a long time (a week or more) when i see it turning red i shut it off and let it cool down a bit and start it back up and works fine. got the **** scared outta me the first time it happened!
Old Feb 25, 2003 | 10:17 PM
nyroc's Avatar
A lot of engines will do that too,
However, a lot of 650's are a bit lean from the factory. They may not be hurt by it, but they don't run as well this way.
Motorcycle riders often richen things up a little more than a typical fuel injected auto motor is set for.
Old Feb 26, 2003 | 12:05 AM
Kawi650's Avatar
I don't like idling my machine like that, the engine is too big and hot enough, if I want to check my fan I have a switch[img]i/expressions/face-icon-small-wink.gif[/img]
Bigtwin700
Sep 9, 2015 09:32 AM
Reactant
Jul 27, 2015 07:45 PM
garyc660R
May 26, 2001 07:37 PM
Klem64
Apr 5, 2001 11:06 AM
ROBBINthaHOOD
Jan 20, 2001 01:31 AM
