99 fourtracs, 4x4 problem
Old Feb 26, 2003 | 12:58 AM
dasoldier's Avatar
Default 99 fourtracs, 4x4 problem
I have a 99 fourtracs thatd been giving me trouble, I recently replaced the battery because it had gone bad and was sure it would start right up when it didn't, after messing around with it I changed the spark plug and she started right up, I came back about an hour later and it wouldn't start again.... any suggestions? fuels good, fuels on, etc... someone mentioned to me heating the plug up and putting it back in there..
email me dasoldierc@aol.com I'm wanting to get this thing running its cold and icey here in oklahoma
Old Feb 26, 2003 | 03:06 PM
action450s's Avatar
Make sure your fuel is fresh. Bad/old/stale fuel can foul up a spark plug easily. Could also be that your carb needs to be tuned/cleaned.
Old Feb 26, 2003 | 04:20 PM
Metimbo's Avatar
Yep, that's what it sounds like. If it sat up for a while and outside, you probably have bad gas and it is fouling the plug really fast.
I would drain the gas and the carb bowl, replaced the plug and see if that helps.
~Tim
Old Feb 26, 2003 | 07:33 PM
2000IAWarrior's Avatar
when u hit the start button does it make ne noises.. or does it act like it wants to turn over or what does it do?
Old Feb 27, 2003 | 12:50 AM
dasoldier's Avatar
yes it wants to start, trys and trys... how hard is it to clean the carb? and I honestly don't know how to drain the fuel? but if you can point me in the direction I'll figure it out...
dasoldierc@aol.com
Old Feb 27, 2003 | 03:58 AM
nick01's Avatar
dasoldier, I was wondering if it is hard to start cause of the cold weather. I live near Fort Smith and it is very cold out for our area this late in febuary. Look on the side of the carb and you will find a primer button, push it a few times and pull the choke out, see if the bike will start up then. If I pull the choke out my rubi doen't always start so the primer is nice because it has never failed me when I use it, even if I don't use the choke. good luck
Old Feb 27, 2003 | 05:16 PM
dasoldier's Avatar
yep, Tried to prime it... think I will take the carb off this weekend... whats the easiest way to drain the fuel?
Old Feb 27, 2003 | 06:23 PM
is your starter bad? try useing the backup starter a few times and see if it will start..if your start hearing the starter silinoid click then u need a new or rebuild yoiur starter..
Old Feb 27, 2003 | 09:20 PM
dzzy's Avatar
Think Action450s and Metimbo got the right idea. First off install your new spark plug, shut your fuel off, find the drain screw on the carb. This will be at the very bottem of the carb and facing straight out at you, brass colored flat blade. Turn this screw out about a turn and you will see fuel draining out the bottem fitting on the float bowl, there should be a hose on it that goes straight down. Drain out what's in the carb, won't be much. Take a whiff maybe of what's in the tank and if it smells like gas, turn your gas back on and try to start, full choke, no throttle. To drain the fuel out of your tank is easy too, just shut off gas, remove gas line, run a longer hose into your gas can, turn gas back on and let her go, be sure to drain the reserve too. If it still won't start, of course look to your carb. If it starts but runs poorly, won't idle, try to take it for a ride. If it still runs poorly, you probably have to do the carb.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
