Amplink Banshee
Old Apr 17, 2000 | 11:41 PM
BatMan72556's Avatar
I have heard that an amplink will make a Banshee hook up better. Well hate to be a dummy but what is it, where are they, how much they cost?
Thanks
BatMan
Slowly doing what I said I wouldn't do adding all kinds of gofast parts to this Banshee... But it runs sweet...Wheeeeeeeeee
Old Apr 18, 2000 | 08:57 AM
fakie99's Avatar
check out the similar post on the yamaha bulletin board on the amp link. i bought one and it does reduce rear end skipping. the price is a heavy $120 here in michigan and i'm not sure if i would spend the money on it again. it's fairly easy to install....about half an hour because you need to cut the plastic clutch/chain guard.
Old Apr 18, 2000 | 11:14 PM
PamFalcioni's Avatar
Basically, the Amplink is a chain tensioner which attaches to the swingarm pivot point and keeps the chain from "slapping". The theory is to keep tension on the chain and remove the delay between power getting from the engine to the rear tires.
It also keeps the swingarm/rear tires from "hopping" under max hp.
They do work. However, I have seen some weird countersprocket wear on a few Banshees that are using them. They are worth the $$, but keep a close eye on the countershaft sprocket (which is hard to see with the AMP link installed).
Old Apr 19, 2000 | 02:24 PM
sAyIt_fmf's Avatar
More than just a tensioner....The amp link ....'in theory ' ..........is supposed to change the angle of the chain against the swingarm.
Look at the angle of the chain with the stock rollers...and again with the amp link installed.
Take this angle....throw in a little math....and the power is better delivered in a strait line to the rear wheels.
This in turn keeps the rear end in more of a consistant not constant contact with the ground....Which in turn will produce more power to the ground.
Old Apr 22, 2000 | 02:14 PM
millhouse's Avatar
I would highly recommend it if you like trailriding...
Old Apr 24, 2000 | 09:33 AM
sAyIt_fmf's Avatar
and spending money on bearings
Old Apr 25, 2000 | 09:47 AM
fakie99's Avatar
well, a quick look at most of the other posts would suggest that bearing failure has not been an issue for most people. the product works more or less, but at $120-150 i can think of better places to spend the loot...
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
