nyroc muffler mod.
Old Feb 28, 2003 | 12:48 AM
2003650's Avatar
Default nyroc muffler mod.
I was just wondering how many of you had done this to your quads, and is it worth it?
Any input would be appreciated.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 28, 2003 | 12:52 AM
RebelDS's Avatar
I'm GOING to do it. I just have to find someone who can weld the muffler cap back on. I suppose taking the muffler off will make it easier to do the work? I want to do it not only for the extra power, but because it's been said that it sounds a lot better. I'm just not sure whether to go 6 or 8 holes and whether to make them 3/8" or 1/2"
Old Feb 28, 2003 | 12:59 AM
2003650's Avatar
I think the only hard thing about it would be the rewelding of the cap. If i do it i think i am going to do what nyroc said "6 3/8 in holes drilled with a 12 in drill bit." Has any one repainted the muffler so a park ranger doesn't get suspicious??? ( I mean if i saw a muffler that had a different color on it i would wonder what was going on-- new weld )
Old Feb 28, 2003 | 01:04 AM
BLUERHINO's Avatar
Its worth it I put 6 - 9/16 holes in and it sounds great
Old Feb 28, 2003 | 07:57 AM
HORSEMAN's Avatar
I took mine off, marked the cap and exhaust tube, cut the end off in a band saw, drilled 6 1/2" holes, cleaned the paint onthe tube and the cap, lined the marks back up, welded it back together, used flat black engine paint, re-installed, jetted, now with a winch and mount in high gear she will pull the tires...
1/2" holes or 3/8" either will produce power your prefrence on how loud.....
Old Feb 28, 2003 | 08:28 AM
trx450's Avatar
If you can, remove the muffler from the bike, THEN do the cutting/welding. I cut mine apart with a band saw, right through the end cap's weld. After the re-weld, you couldn't tell I had it apart! I also tacked some s.s. screen(1/8" grid) inside the outlet, so the ranger couldn't shove his pencil too far up the muffler. GOOD LUCK!
exmotocrosser
Sep 13, 2019 06:12 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
slowgsxr97
Sep 8, 2015 07:33 PM
