Top end cut out
Old Mar 1, 2003 | 12:11 AM
sportkc's Avatar
Default Top end cut out
I finished braking in my 400 that was just trail ported and at the end of a 300-400 foot run it feels like it is running out of fuel. The carb is still the stock one with a 310 jet. I was just wondering if this is a normal problem or do I need to start checking into my fuel system for a clogged filter or line.
Old Mar 1, 2003 | 12:16 AM
2manytoys's Avatar
You may need to increase your main jet. It is starving for fuel on the top end. Usually when you add a pipe or porting you must rejet.
Old Mar 1, 2003 | 12:17 AM
mojave300ex's Avatar
Sounds like you have a piece of thash in your main jet. When the main-jet is cloged, idle to 1/4th is fine then it will start to bog when you get just over 1/4th throttle. Is that about what it's doing?
Old Mar 1, 2003 | 12:24 AM
sportkc's Avatar
It runs great for about 300-400 feet then it falls flat on its face. It feels like the float bowl is running dry.
Old Mar 1, 2003 | 01:07 AM
2manytoys's Avatar
Yes because the main jet is to small.
Old Mar 1, 2003 | 01:16 AM
what does a 400 come with stock?
Man that still sounds like somthing is cloged. Myn was running crappy... it did exactally as what you decsribed, I cleaned my carb and it ran like hell. Hey I have no clue about 400 jetting. Just my experience
